If the fog light holes came covered up when I bought it do they just pop out or do i have to cut them out?
How much was the cutter and was it accurate... was the cut sloppy? How did it turn out once you finished making the cut?? I'll need to cut mine out too.dje1973 said:You have to cut them out. I used a 4" door knob cutter from Home Depot.
Have you made the cut outs for your fog/driving light?? If so what did you decide on doing and did it work?? Mine is a '98 Durango with the same problem covered up fog light holes.blue2000sport said:If the fog light holes came covered up when I bought it do they just pop out or do i have to cut them out?
How did you make the cut out for your fog lights? The fog light kit that you used was it factory or aftermarket? I hear its better to go with factory but lately after reading more posts its swaying towards aftermarket. I'll have to cut out mine here too just need to know which one is the best way on completing this.Bigguy18LSU77 said:I cut mine out and they look like crap. I couldn't figure out how to make the foglights stay in the holes and lost one. Any help on this? The mounting brackets I got with the kit sucked and I didn't see anyway to mount the brackets to my truck to make them fit.
code3 said:How did you make the cut out for your fog lights? The fog light kit that you used was it factory or aftermarket? I hear its better to go with factory but lately after reading more posts its swaying towards aftermarket. I'll have to cut out mine here too just need to know which one is the best way on completing this.
When you cut out the holes did you remove the bumper or did you cut with bumper attached on vehicle? How would I know where to cut? Is there a line to follow??Mr-SXT said:I did mine a few months ago and just used a REALLY sharp a$$ knife and took my time .... mounting them i got the OEM kit and all came with 2 big metal brackets that bolt onto the front of the frame and holds the lights in the holes.
Are you going to try what Mr.SXT did and used factory w/brackets.Bigguy18LSU77 said:I would go factory. The aftermarket ones I got from Autozone sucked. One fell out so I took the other one out and just have ugly holes there now.
