1 - 6 of 6 Posts
O
I have an 04 dakota and I would like to put on a flowmaster muffler but i'm not sure as to what size inlet, center, offset, etc..... can anyone help with this?
well the pipe should be 2 1/2 inch and i would say center and center. you will have to have a bit of pipe added to make up the space. The flowmaster is going to be shorter than your stock muffler.
I have the 40 series Delta Flow on mine. Sounds sweet. The part number is 942542. Hope that helps.
I looked under the truck the other day, it seemed like it was a center in-offset out, please correct me if I am wrong. I was thinking about leaving all the stock pipes, just adding another piece of pipe to make up the difference in the length of the mufflers.
I like trucks
I have the same as Wolfman, it does sound sweet too :biggthump
Good luck
O
Discussion Starter #6
Thanks for all the help....the part # was great thank you. I'm ordering one tonight.
1 - 6 of 6 Posts
