1 - 1 of 1 Posts
Whether you’re fixing a broken wire,the pig tail on a headlight switch or wiring up a new set of gauges, one thing's for sure the best way to make an electrical repair like this is to get a soldering gun and cut the bad end off.
Once the bad end has been removed instead of butt connecting all of the wires together solder them and also use some heat shrink tubing to help protect the new connection.
Soldering makes for a more reliable and better conductor and connection than using plastic butt connections to reconnect loose wires or bad ends.
1 - 1 of 1 Posts
