LOL Im here just been real busy with my Gen 1
Well I started to build the motor for my Plum Crazy Gen 1
here are the parts as follows
1991 318
Comp Cam 20-243-4
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 3,000-6,500 RPM
Intake Duration 050 inch Lift: 244
Exhaust Duration 050 inch Lift: 244
Duration at 050 inch Lift: 244 int./244 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 292
Advertised Duration: 292 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.501
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.501
Valve Lift with Factory Rocker Arm Ratio: 0.501 int./0.501 exh. lift
Lobe Separation (degrees): 110
Crane Roller Timing Chain
Keith Black Pistons KB 399
Bore (in): 3.940
Piston Material: Hypereutectic aluminum
Piston Style: Flat
Compression Distance (in): 1.810
Dish Volume (cc): 5.0
Valve Reliefs: Two
Wrist Pin Style: Press fit or floating
Pin Diameter (in): 0.984
Top Ring Thickness: 5/64 in.
Second Ring Thickness: 5/64 in.
Oil Ring Thickness: 3/16 in
Compression Ratios with a 63cc head is 11.21
57-12.25
60-11.7
64-11.0
68-10.5
Eagle SIR I-Beam Connecting Rods
Connecting Rods, SIR 5140 I-Beam, Bushed, Mopar, Small Block LA
Edelbrock Performer RPM Cylinder Heads
Cylinder Head, Performer RPM, Aluminum, Assembled, 63cc Chamber, 171cc Intake Runner, Mopar, Small Block,
Edelbrock Performer RPM Air-Gap Intake Manifolds
Intake Manifold, Performer RPM Air Gap, Dual Plane, Aluminum, Natural, Square Bore, Chrysler, 318/ 340/ 360
MSD 6AL CD Ignitions
Ignition Box, MSD 6AL, Analog CD, with Rev Limiter
MSD Blaster 2 Ignition Coils
Ignition Coil, Blaster 2
MSD Pro-Billet Distributors
Distributor
Holley Model 4150 Carburetors 750 cfm
Hooker Super Comp Headers
My Virtual Engine Dyno say this little combo is good for
[email protected] rpm and
[email protected] rpm lets hope im this close. The quarter mile times are 12.27 @ 109.737
