1 - 5 of 5 Posts
Fuel Monster
Hi guys,
been away from the forums for a while, busy with everything under the sun it seems.
Here's the situation I'm currently in.
I'm in the process of getting all the ducks in line to pull the 3.9 out of my '02 Dakota and drop in a 5.9 from an '02 Ram Van (I got the van for free).
I've been doing alot of reading and received some good information from some members but here's where I'm stuck.
I can't find a PCM from an '01 to '03 Dakota with a 5.9 (would prefer an PCM from an '02).
Where I'm located up in Canada, there are a limited number of RT's and searching across the county have had very little luck, without paying an arm and a leg for shipping.
I was looking on Mopar Super Center and found this ...
http://www.moparsupercenter.com/engine-controller-5-9l-magnum-automatic-transmissionp5249935.html
Here's my question, will that work for my swap? or not?
Even with shipping from the states, that would be cheaper (and brand new) then some of the used ones I found on the other side of the county.
Any input, suggestions, advise is welcome.
Thanks
Fuel Monster
Discussion Starter #4
I might have a line of a PCM from an '02 Durango RT.
I know its AWD but SynRG was thinking that it should work.
I'm still waiting to heard if it has security (grey key).
But the main question, will a PCM from a AWD '02 Durango work in my '02 Dakota swap?
1 - 5 of 5 Posts
