1 - 5 of 5 Posts
i just installed a mopar m1 single plane intake manifold and once i started it up it kinda ran rough, and my engine light went on right away. i checked the codes and i got the p0351 which is because of my msd ignition which im fixin, but i got p0118 which is (Engine Coolant Temperature sensor circuit, high output). and my engine only stays on 130 degrees. does anyone know wat this means and how to fix it?
see i think my mistake was havin someone help me who likes to hack his projects, and i saw him drop the stat in but i didnt even check to see if it was upside down. ill check that tho, thanx.
Discussion Starter · #4 ·
well i checked the stat. i even replaced it with a 180 stat just incase it got damaged and its still doin it. i also realized its overcooling. once i start the engine the electrical fan starts right up which shoudnt until ive reached 210 degrees. im guessin i damaged the engine coolant temp. sending unit in the intake manifold behind the altenator durin installation. could that be it? and if so can i just buy one of those at a parts store?
2000 6.7 R/T
Its VERY easy to damage the plug end on that sensor if your not careful taking it out. Go to the dealer and spend the couple bucks on a newone. After you put it in, reset your comp and you should be good to go :biggthump
1 - 5 of 5 Posts
