i've still got a few more things to check out but its looking more and more like i need to replace my ecm. the truck is a stock 2000 durango r/t. do i have to get a special ecm do to the factory tuning causing it to have to run on premium? id like to get a normal one if i can but even the mopar ones arent compatible with my truck.
reason i might need to change it is be cause of a "NO BUS" code. tested the battery and alternator with both passing. is there a way to test the voltage regulator in the ecm to see if its going out? i found some at napaonline.com but i dont know if they are compatible.
thanks
mike
thanks
mike
