1 - 13 of 13 Posts
Will this work? Money is tight but i have a brand new complete set of rear brakes off a 99 durango. Drums to backing plate. I hate having these lay around so will they work on a 99 dakota? After 112,000+ miles its time to replace the rear brakes.
· mopar or no car
no the dakota is an 11.whatever radius and the durango is a 13.4 something for the front and 12 somthing for the rear i forgot all the exact numbers casue i haven worked on my truck in years but that all change when i ETS
The 99 Dakota came with either a 9" or 10" rear drum and the same year Durango came with a 10" rear drum. It is possible the drum from the Durango will fit you Dakota but honestly your best bet is to take the rear wheel off the Dakota and see if the new drums fit.
Discussion Starter · #7 ·
I would be putting the whole rear brake system off the durango on the truck. From the Back plate to the drum. I'm just wondering if the backing plate will bolt on to the dakota axle.
· RatBastard
You can check the data sheet in your glove box. It will say what size rear drums you have. My 99' dak had 10" drums and they were a PITA to source.
did you ever end up trying this swap? im trying to see if i can swap my drum/backing plate from my 8.25 axle to my 9.25. no one really answered the right question. are the backing plates interchangeable?
Discussion Starter · #10 ·
No i haven't had a chance to try it yet. From what i can tell backing plates look to be interchangeable. I'm hoping to get mine changed over next weekend
any updates ?
1 - 13 of 13 Posts
