21 - 34 of 34 Posts
· Resident Craigslist Whore
well i lost them on egay oh well sorry man
they must not have been what i was lookin for then, cause every set of mirrors that i need, i had bids in on ebay. i just picked up the drivers side about 10 minutes ago, $70. now i gotta try and win the passenger side, and the current bid is $61. thanks tho, man.
as long as the match your plug they will. and even if they dont, you can always just splice the wires and eliminate the 2 different plugs
· Chillin The Most
Discussion Starter · #26 ·
6shooter, Got my mirrors the other day! So this is how the prong looks. 3 metal tabs with 4 wires and 2 of the wires going into one prong.
The prongs are only in the top 3, there is nothing in the bottom 3
now im not sure if 1) ALL 01-04 kotas have the 8 pin plug or 2) only the 01-04's with the heated mirror option had 8 pin, and then just power, non-heated mirrors had the 6 pin. but one thing im almost positive on, is that 97-00 ALL had 6 pin plugs. like i said, if you got a 6 pin female plug inside your door panel, your golden, the ones you got will plug right in. but if your truck is equipped with 8 pin, then your gonna have to get crafty and do some splicing.
and im pretty sure that the 2 wires in one pin are the ground wires for each motor, then the other two wires run power to each motor in the mirror. i couldnt tell you which wire is the up-down and which is the left-right motor, tho. i havent looked into it that much yet. i got my driver side heated mirror today, now i gotta get the passenger side one soon, hopefully.
Ill just have to wait until it warms up or check it out when I do the body lift
shit, its 14 here and like -2 with the wind, i just popped my door panel off and made sure the mirror i got worked. took about 15 minutes. the door panel is only 5 screws. if you dont have a garage, just dress warm :jester:
· Se habla Español.
well that sucks. but i guess it answers my question. so all 01-04 kotas have 8 pin plugs for power mirrors.
That is correct.
21 - 34 of 34 Posts
