1 - 8 of 8 Posts
so my driver window just stopped working and i took my door panel off and there is a cable that is just hanging there. any idea what i can do to fix this problem?
The Anti-RUB
Do you mean a wire or a cable? If its a wire hard to help without knowing which wire it is. Pictures speak 1k words. If its a cable (with no shrink wrap coating) then it is the cable used to raise/lower the window via the Window Regulator. Only way to fix it is to replace the window regulator & motor. They come as a unit. Dealer will charge you $400 for a replacement. Kragen/O'riely, Pepboys and Autozone carry aftermarket window regulators for $100. Good luck...
yeah i am pretty sure its the cable that raises and lowers the window because when i press the window button i can see it moving inside the door. thanks for the help.
The Anti-RUB
Call around your local autoparts stores. In my area its around $100. Replaced mine a couple months ago.
Replaced the rear pass. side for $40 from the junk yard about 2 months ago.
Just make sure they test it for you before you buy it
1 - 8 of 8 Posts
