I am trying to find the switch that turns on the interior lights when you open the door. I am getting ready to install steps & would like to put some lights over the steps when you open the door.:huh::blahblah:
Moderator
Its built into the door latch. You dont want to tie directly into the switch, you want to use the negative dome light output from the CTM. It'll be under the dash at the big junction block the yellow wire with the purple stripe. If you use LEDs for the step lights you do not need a relay or anything - just wire them straight to the dome circuit.
That is exactly what I was going for. (LED's) thank you:clap2:
