When I was looking at buying my first Dakota I noticed that all the dakotas had bad driver door hinges. I know it's because those doors are the ones used most often, but on mine the door is actually broken. Is this a common problem on dakotas and if so is there a fix for it?
I already purchased new door hinge repair kits including the pin for the drivers side. The right side is in great shape.
I am thinking that I will weld the door back together to make it work properly again and then grind the welds down. Then weld another plate of metal around the area so that it reinforces the door.
I will post more pics this weekend when I take the door off to fix it.
idk if he is member here, but his screen name is 'ole-busted' and he just had some door problems and welded his back on. Try messaging him if you can find him on here or on the other sites.
