What is the lock and unlock voltage for the door actuators? I’m trying to bypass the CTM and connect them to an aftermarket alarm system but don’t want to fry them by just applying 12v if that’s too much.
I need to run a separate relay to trigger them. My CTM is fried and won’t trigger them. I’m concerned if the CTM output voltage is supposed to be less than 12v it could damage the actuators if I run 12v.
OK.
Looking at the wiring diagram it shows "door lock relay output" and "door unlock relay output." That shows it very likely to be 12v. Electronics would run at 5v, not usually any sort of motor or actuator.
