1 - 11 of 11 Posts
http://cgi.ebay.com/ebaymotors/20HP...r_Truck_Parts_Accessories?hash=item4cecdc17f3
will this work at all? improve any power or mpg? i know it def wont give even close to 20hp but for $6 if it does anything positive its worth it
idk if i trust putting a resistor in place of a sensor, i only do this kind of stuff on my camaro when i knowingly am doing something that will give me a check engine light, and i def dont want to produce a check engine light
NO!
#19 ƃop ǝnןq ǝןʇ&#
If you wanna try it go to radio shack and spend 10 cents, and not 6 dollars. But yeah they dont work.
Yea...that's what I did....got a resistor with the value they specified in the auction....
again, didn't notice anything different
Blown and Squirted
Move your IAT sensor to your cold air intake instead of you intake manifold. This will enrich your mixture and pull less timing when the motor is hot. Be forewarned its probably already running too rich.
Gen I FTW
will this have any bad effects later down the road though ?
will this have any bad effects later down the road though ?[/QUOTE
More money spent on fuel, and a slower truck. I've moved mine around at the track....No diff in ET's.
Blown and Squirted
With the sensor in the stock loaction, you can get poor hotstart driveability when the sensor is heatsoaked. As far as performance is concerned, you have to have a lot of airflow mods to not be way too rich to begin with on a jtec pcm.
Gen I FTW
so one is better off to just leave it in the stock location ?
1 - 11 of 11 Posts
