Need usable details:
What's happening when this chime goes off?
Just driving or sitting still, it happens about 2 minutes after startup.
Sitting at a light? Turning corner? Braking? Driving around with low washer fluid?
Going straight each time as I recall.
Does it always chime in the same circumstances?
Yes.
Can you make it chime when you want to?
No. I can only make it go faster or slower (due to mods
) when I want to.
Get the picture? Need more info.
Do all of your instrument panel warning lights work?
Yes.
You could have a situation and not know it, on account of a burnt out bulb.
I thought about this and was hoping that was the case since the third brake light bulbs were out. I replaced these when I did the headlight upgrade and checked all other exterior lights to be sure they worked. All fluid levels are OK as well.
