Hi all, Ok here is my problem. I have a 2001 Durango 4.7 and is loosing coolant, No leaks found ( yes this has the rear heater and a/c ). I filled it up now it blows it out the over flow, no it is not over heating ( checked it and also the guage does not show it over heating and no warning lights from the computer or codes ). Local garage ( trust the guys plus I do work for them on the side ), could not find anything did a pressure test and pulled a vacum on the cooling system, and checked the cap 21 pound (even replaced it) ... all good. Like I said no leaks, no smells unless it comes out of the over flow. All summer it was ok now it is cold out and it acting up.... when the coolant comes out of the over flow it is like someones dumping it out, not steaming out like when it is over heated. Not even my friends at the dealer service center understand it.
ok now ill take you back to the beginning. 5 years ago it EXPLODED the rear heater core,. Dealer (father inlaw is a manager there and I know alot of the mechanics ) replaced it ( warranty ). 6 months later it happened again, fixed it under warranty. 2 years ago lost the relay for the electric fan (over heated ), again fixed. 4 to 6 months later it over heated again blow out the bottom of the radiator (plastic junk), again fixed (warranty). 3 months later another fan stopped but we caught it nothing broke but the radiator warped and it the fan, again warranty. 2 weeks later fan stopped again but i caught it and noticed the radiator was in the fan... warranty expired (screwed) so I spaced the electric 1/4 inch away.... no problems... now I am back to problems as I stated above.
What is going on with this "Lemon" durango ????????????? I don't have any smells or leaks (unless it coming out of the over flow) no tranny problems no heater problems as of yet, but I am sure they will come sooner or later. Yes it has a extra trans cooler and its own fan.
My wife drives it most of the time and does not beat it and it is serviced 3 times a year, oil changed every 3000 miles.
[/SIZE]MS"]
[/SIZE]MS"]
