Does anybody have any tips or write ups on how to change out control arm bushings on a 95 2wd? The lowers seem like normal but can't figure out the uppers with the bar going through them. Thanks
Home Owner....
undo the fasteners holding them down. that is the pivot rod for the upper arm and is also your camber adj point.
it goes through the bushings so be careful pressing them out or melting them out. i forget if ya gotta reuse the outer shells or not.
It's not my fault!
I have done mine. The top ones are a pain. Unbolt everything. I used a press to get some of them out. One was really worn though, so I had to replace the casing shell. The autozone replacements included new casings.
Ugliest Truck on here!!!
they need to be pressed in and out. just save a headache and shell out a little cash to get it done.
