1 - 17 of 17 Posts
the wife just got her clear corner lights in the mail today from eastcoast truckin, the package only came with 2 orange bulbs. there also was one small bulb pre-installed in each light
Did I get Jipped or are you sapposed to use 1 factory bulb in each light???
That's the way the companies shipped them out, it's not Chris's fault. Each lens does use two 3157 bulbs plus one 194 bulb. Depending on your state laws you may be able to re-use your clear bulbs for all of the lenses, although some states do require the use of amber bulbs in either the corner or all positions.
If you want to use ambers all the way around it's easy enough to buy some amber 3157 bulbs from just about any auto parts store.
One of the Elite
Get These
You could use the clear bulbs, or amber to be safe. I went to advanced auto and got the bulbs below. They are silverstar "corner" bulbs. They are like an irradescent blue, so they look nice and clean in the corners, but they shine amber. My 194 bulbs pictured below are normal amber bulbs that have been painted with engine enamel silver paint. They were lightly dusted, or spectacled with the paint. Dont paint them completely solid, or the light wont shine through.
Take a Look.
~CYCLONE_06
Discussion Starter · #4 ·
should I use any silicone to seal the lights once they are installed???
One of the Elite
Well, what you wanna do is... seal the outer perimeter on each headlight and the two corners... where the back and the front come together. You can get some clear silicone from Napa or a marine store. After it dries, take a drill and drill a 5/8 hole under each bulb port in the headlights (on the headlights, you might wanna drill two side by side) and the corners (drill one hole under each bulb port). The holes create ways for air to circulate through... and stay dry, and the silicone prevents any outside moisture from getting in.
Hope that helps.
~CYCLONE_06
Discussion Starter · #6 ·
Hope that helps.
~CYCLONE_06
am i doing that where the bulb actually plugs into the "port" on the back of each light...?
One of the Elite
Well, you can do it there, or anywhere near it. Something like that. Just put it somewhere so that water wont get into the hole. As long as the holes are on the underside, should be ok. Last time I checked, water doesn't run uphill. ;)
~CYCLONE_06
Discussion Starter · #8 ·
ok guys just got back from autozone to pick up a few things...heading out to do the install now, thanks for the tips and you will be hearing from me again later this evening....Wish me luck! :slice:
:toast:
Discussion Starter · #12 ·
Well fellas got'um in, I didnt use any silicone either, everything looks to be pretty much water tight from the factor. I did have one little hicup... blew the parking light fuze when I was doing the wiring for the small bulb...ooops, but no biggie. I did notice that the 2 bulbs I bought burn lighter than the 2 sent to me, so of course I have to get 2 more from autozone and switch them...wife doesnt like it. She also has a street scene grille comming to so once I get that I will be sure so show you guys the finished product.
:toast:
:toast:
Glad to hear that they went in easy for ya. :toast:
can't wait to see the pics
Its not that I don't like it, It's just the bulbs that come with it and the ones we bought at auto zone are to different shades of Amber, One is lighter than the other .
go with whatever makes you happy
1 - 17 of 17 Posts
