Has anyone changed there's? Is there a gasket out there? Did you replace bolts with stainless steel ones? and what type of gear oil did you use? I'm looking at synthetic (royal purple) Any feedbacks will be appreciated.
Why Chrysler only friction modifier? I have never used the Chrysler brand stuff, just whatever is available at the local parts store for years.fastM said:You don't need a gasket, use a good silicon gasket sealer, like Form-a-Gasket. You can replace the bolts with stainless if you want. Use any good synthetic gear oil, be sure to add Chrysler (only) friction modifyer (4 oz) if you have a limited slip.
GOON'S D said:I would rather not go to the parts store covered in gear oil with the bolt in my hand if I can avoid it.
