1 - 5 of 5 Posts
T
Can anyone tell me if their is a way to check my engine codes when my check engine light comes on without taking it to the shop. I have a 98 Durango 5.2L.
T
Discussion Starter #2
If there is an Advance Auto parts or a Auto Zone near you they can check it for free. If you lived near me I could hook it up to a snap on tool. Hope this helps
2000 6.7 R/T
Stick your key in the ignition do the following sequence:
off-on, off-on, off-on. That last ON you have to keep the key in the position and the code will flash in your odometer reading. It will start with a P----
I don't think that works on 98's. you need a code reader. tiggerweed has some good advice.
Correct 98's need a reader.
1 - 5 of 5 Posts
