So the other day I am cruising down the highway as soon as my truck gets above 35-40 my check engine light comes on the truck doesn't shift into overdrive and my cruise doesn't work. When I turned the truck off and back on no check engine light until I get about that 35-40. Currently the truck has no issues everything is working again but I need to figure out what is going on here. I have not pulled the codes (I don't happen to have a scan tool) I am hoping this is a common issue I am thinking either my vehicle speed sensor or there is a relay that has gone bad. :huh:
engine codes
Switch your ignition on and off three times, look at the check engine light count how many times it flashes 5 and then a pause then 5 is 55 thats the finishing code post any codes that come up before that
I hate you people.
Sounds like a bad OD module. Had 94 5.2 Dak with the 46RH but never had any sort of issues with it. But, definitely go get it scanned, at any of the auto parts stores, and then report back what shows up.
