Forgot to mention, after the car trip, I checked the hoses and level of coolant, none has leaked or sprayed out, and the hoses have not slipped off.
damn thats good to know. Im going to be checking that soon nowDamn. I while changing the clamps I noticed the plastic in-hose fill cap was basically deteriorating from the inside. Replace it with a new one but talk about poor design. View attachment 60930
Sent from AutoGuide.com Free App
Clamps or the housing you see in the pic?ahh. see my fix now.
ok, where to get the metal/alum housing?
I thought my water pump is broke.
good to know.
thanks for the share
Well let me know if this helps man. I had coolant leaking and boiling out of the overflow tank. Looked closely and found that to be the problem. Hope I helped man!!Thank you Thank you Thank you!
I have been having the EXACT same symptoms while driving through Colorado and Utah. I will try your solution tomorrow and will report back.
My Story:
I had a leak while driving across country from Detroit to Provo hauling a travel trailer with a 2001 4.7L Dakota Quad Cab Sport. The truck overheated in the middle of absolutely nowhere, but the coolant was everywhere. A call to AAA brought "Ol' Reliable" towing and service. The owner, Fred, was the nicest guy on the planet. He towed the truck AND the travel trailer, dropped us off at the most fabulous Victorian hotel in Walsenburg, the La Plaza Inn, where we had a great late night dinner and drinks with friendly old cowboys. The next day I hung out at the Ol' Reliable service shop with Fred and the mechanics. They pressure tested the cooling system and discovered a loose hose clamp. That fixed the overheating and major coolant leak, but I have still been boiling coolant and leaking a bit now and then from an unknown source somewhere around -- but not from -- the radiator cap.
