1 - 6 of 6 Posts
I just got a 1993 Dakota with a 5.2 ,auto and 4x4. from the looks of it and info I found on here it appears to be a 46rh. the tranny has no reverse and slips bad in forword gears. my question is. can a 93-98 jeep grand Cherokee 5.2 46rh work in my truck? like just a simple swap no making things work. I ask because I cannot find a 46rh anywhere in my area for my Dakota but I have found lots for the jeep.
Jeep 46RH 93-95 and 46RE 96 to 98 have the starter on the wrong side for your truck.
crap...why did they do that? same motor same tranny but put the starter on other side...makes no sense.
Discussion Starter #4
what about one from a dodge ram and if so what years do I need to look at. and will my transfer case bolt to one of these trannys?
Not sure what year Ram trannies will fit due to wiring differences. T-case bolt pattern is the same along with the 23 spline input shaft BUT there were some differences over the years with the amount the input shaft engaged the trans.
1 - 6 of 6 Posts
