i bolted on the v8 TB i bought from realdeal. the throttle bracket that it came with was too long for the throttle cable, so i reused the bracket off the v6 TB. it causes the TV cable to angle a bit toward the linkage. truck ran fine since i did the tb swap on saturday, but this morning i started up the dak and got a p1494, which thru googling is " Leak Detection Pump (LDP) pressure switch problem - electrical or the pump itself. "
anyone think that my TB jerry-rig could cause this problem? i reused the gaskets that were on the original TB, as they appeared ok. the only recent electrical mods is wiring up a sub amp and powergate lock. truck has only 18884 miles as of this post. has never had the check engine light come on except for a p0123 when i left the TPS sensor unplugged right after putting on the v8 TB.
please :help: thanks in advance
