2001 Dodge Dakota Quad Cab 4x4 with 4.7 automatic transmission.
I have had a lot of trouble with the ABS system on this truck and have terrible brakes.
Last time and a few years ago the brake solenoid was found to be the problem causing the rear brakes not to engage.
The braking on this thing sucks even though the complete PB master cylinder and booster has been replaced.
I am fully aware that ABS is better than standard brakes but I would settle for standard brakes at this time if removing or bypassing the ABS would help.
My questions:
If I completely bypass the existing ABS system and even install an adjustable proportioning valve, will I lose my speedometer and will it trip a code causing the engine to go into fail safe mode?
If so is there a way to still bypass the ABS and retain the speedo and not have the engine code?
Note: Please no sermon on safety and the need for ABS. I totally understand the need and the dangers of disconnecting it.
If it doesn’t work and I can no longer find new OEM parts then I am no longer interested in throwing money at used parts that do not work or only work for a short time and then again fail shortly after.
I am looking for a good solution in elimination of the ABS and having good standard brakes.
Thanks to all who can offer good solid information and has a good understanding of the ABS system on this year model with my options.
Thanks
My questions:
Thanks
