Hey guys i have a 89 dakota 2wd, reg cab , short box that i am in the process of swaping in a LA 360. Im looking for a wiring diagram of the firewall bulkhead. If any one has one would be greatly appreciated.
I want to thank you very much for this. I just had to replace my connector myself. After working on it all day yesterday, I was able to get my truck fired up. This diagram helped me out soooo much. I pulled one from a 1990 Dakota at the junk yard and it was in excellent condition. I couldn't find one to show the wiring of a 1990 so I figured I will just match the wires I do have a figure out what needs to be re-wired. I only had to re-wire my overdrive switch and solenoid. I sacrificed the speed control as it never worked before and I can revisit it later. I cannot thank you enough for this. Crazy how you posted this almost 5 years ago and it came up in a search on Google.I don't have the 1989, but here's a 1988; should be basically the same, with the possible additon of the TACH signal (don't get excited, it's 2x per revolution, or half what your engine is putting out) and no, I don't know where it comes in either (since I have a tach-less 1988.)
RwP
