Broke with a dream.
our driver side brake light is not working, and one of the connection male ends has been all busted up (i guess when we took the bed off)
i would have taken a picture of it before i left for work but didn't think of it then.
anyway, does anyone know how interchangeable the brake light connectors are?
the local junkyards have a couple rams and dakotas, and im hoping the connections are the same. I'll take the part and check personally later, just hoping I can get a heads up before i head out.
PS its a connection that leads from the main harness, then splits into a T, which then feeds to the tail light connections, which are fine, its the end of the T that feeds from the main harness into the ensuing tail light connectors.
don't feed the bears
the only problem you might run into are the colors of the wires.. other then that the T's should be the same for the gen 3's ( at least thats what my trailer wiring kit said)
