Got energetic today & pissed away another $30
. I got the speed sensor & swapped it & STILL have both ABS & Brake dash lights on (I did disconnect the negative cable while this was done). Still have that annoying double-ding as well.
The only thing I can think of at this point is the ring on the axle where the rear mounted sensor (that has already been replaced that said it would NOT correct a speed sensor problem) picks up the ABS signal. This sounds like a lot of work, so it will have to wait.
In the meantime, I have to replace my defective Moog tie rod ends & I'm going to fab up (i.e. weld O2 bungs on one) a round 3" in/out cat. converter for a better fit between it & the tranny (the oval one is tighter than I care for). I'm also going to add a 70 Series Flowmaster while I'm at it.
