i got a 4/5 drop and the tires are hitting the wells and the truck is very bouncy can it be my shocks i have the beltech shocks! should i get hotchkis or Doetsch with the firm feel i seen scotts truck has very little tire to well clearence! (the 600hp blue dakota) www.gsmotorsports.com any input would help! when i stop the tires even hit the wells from the weight transfure
how did u lower the rear? if you used springs they might be too stiff. as far as the tires go are u sure u got the right size, and that your wheels are the proper backspacing?
I don't think that shocks are going to help enuff. A stiffer shock will help some, but will not get rid of the problem all together. You might have to go to a smaller tire, or stiffer or taller spring.
