I have recently put a 2/4 Belltech Drop Kit w/Nitro Active Shocks on my 01 Dakota. I am running the stock 16's (255/65-16). I am getting some tire rub on the inner wheel wells up front, usually when the truck is close to bottoming out. Does anyone else have this problem? Is there something I can do to fix it? Maybe stiffen up the front suspension with some stiffer springs, shocks, etc.
:help:
(Some of you have probably already seen or have posted something for this, but I thought I would put it on it's own thread.)
Discussion Starter #2
NO MORE TIRE RUB!!! :woot:
Thanks to everybody who responded to the other threads, I got a lot of helpful tips. I just went with the simplest solution given, go to a shorter tire.
Got a question for everybody out there with a 2/4 drop. What it the largest overall height I can go with and not have a tire rub problems. The stock tires I was running were 255/65-16 (just over 29"), which was causing all the rub.
(When I get back from spring break I should have some new pics of the truck to post.)
