Turn key, Start it, Truck starts and runs.
battery Gauge goes All The Way To Left.
Then Maybe Next time I Start it, start and runs,
battery Gauge shows "normal in the middle range"
Seems to happen more often in the cold, however it has happened even when engine is warm.
AAA, Replaced the battery as it was sub-par.
still happens as above.
2004 Dodge Dakota SLT4.7L V 8, sohc Magnum5 speed Auto Tran 97553 miles
Thank you.
C'mon Dodge - NEW DAKOTA
Certainly sounds like a bad connection, check your harness over including the connectors going to the controllers, your grounds, and fusebox & relay connections.
