So there is this Dodge van guy on another forum who started a thread on this topic on 07-01-2010, 09:31 PM
And he came back 4.5 years later to update it to share what he learned in the interim.
Bottom line is this for us with 15-20 year old vehicles: Our electrical contacts are oxidizing inside the plugs in our harnesses and the connections to our PCMs, etc.
For me personally, I have been diagnosing a "no canbus" no start situation or various sensor "open relay" trouble codes in my wife's 2000 Dodge Dakota 4x4 4.7L gasoline engine over the past year. And have gone through 5 defective replacement PCMs since.
I just sprayed some CRC contact cleaner into the three female plugs and on the bright brass shiny pins on the replacement PCM which I just received earlier this week, let them dry for a half hour -- and when put back together, the engine started immediately.
It was "no canbus" a half hour earlier.
Now I think that all along the problem or one of the problems has been oxidation on the three female plugs on the harnesses where they connect to the PCM and that I may owe an apology to the replacement PCM provider who graciously kept sending me new refurbished replacement PCMs under warranty.
I mean put a copper wire under the hood in your engine compartment and don't do anything with it for 20 years. Wouldn't it get black, green or some other form of oxidation on it which could make electrical connections intermittently fail or fail altogether?
I will order the:
1. mini Q-Tips
http://www.ebay.com/itm/Tamiya-Amer...efaultDomain_0&hash=item258b89a994&rmvSB=true
2. Caig DeOxit D5 spray
http://www.ebay.com/itm/Caig-Labs-D...efaultDomain_0&hash=item540ae3c3ea&rmvSB=true
3. Caig Gold contact conditioner
http://www.ebay.com/itm/CAIG-Labora...efaultDomain_0&hash=item3f2748f8ad&rmvSB=true
4. Caig Shield contact protector
http://www.ebay.com/itm/DeoxIT-Shie...efaultDomain_0&hash=item19ec71802a&rmvSB=true
All of which landyacht318 recommend in the following thread:
http://dodgeforum.com/forum/dodge-ram-van/251312-engine-shuts-off-bad-connector-to-pcm.html
and set about cleaning every electrical connection on the exterior on my wife's Dodge and on my 1995 Bronco and on my 2002 E350.
You may want to consider the same if you are chasing an electrical gremlin.
petrock on this forum said the following about vehicle electrical issues, which I now consider very wise:
"Mechanics look to the component. Electricians look to the wiring."
Guide to Caig products:
https://system.netsuite.com/core/me...wDAlJ1NDQH&vid=rfNKGgwDAmN1NHU2&cktime=131852
I will order the:
1. mini Q-Tips
