I'm researching the reality of swapping in an NV3500 in favor of the automatic currently in place in my 99 SLT CC 5.2L 4X4. I've posted this on a few boards already...I'm just going for maximum exposure. I'm not interested in high performance modifications, just something stronger than the auto that can stand up better to towing and the like. My goal is to come up with an approximate cost of doing the swap and compare it to overhauling the auto and building it up at the same time (shift kit, heavy duty planetaries, etc etc). The swap seems do-able but some things remain vague to me:
Does anyone know if the NV-242 transfer case from my auto will bolt up and mount ok with the NV3500?
Do all 5 speed club cab daks have two piece rear driveshafts or just the 4X2 ones?
I've read that the crank trigger sensor from the auto will need to be "spaced back" from the crankshaft due to the size of the flywheel. What is this all about and how is it done?
I understand the computer needs to be replaced. Is this just the unit on the right fender in the engine compartment, or is it one of the other computers around the vehicle as well (I understand there's 3 of them in total).
There's a speed sensor in the tailshaft of the auto. What happens to this when the 5 speed goes in. If it's abandoned, where does the speedometer get its signal?
Finally, what has to be done regarding the neutral safety switch and wiring in the clutch pedal position switch so the engine will still start?
Sorry for the copious questioning and thanks for any help and insight.
