C
copeland
·Guest
Ok so I've had my Dak since the beginning of January. Today it went in for it's first oil change (5500 km). I went down and washed it up, and cleaned out the interior.
I later noticed just how rough my paintis looking. Now for a truck that is only three months old, with relatively average/low km, it should not look as it does. Mind you I have taken it to work a couple times to pick up lumber and the inside of the box and rails are showing above average wear (no biggie since I was planning to spray in line it.) but the cab, the cab has these little rock chips all over, they don't go down to metal (some do) but they leave white marks signifying it has pierced the paint. also there seems to be a lot fo fine scratches (not like wipe scrathes but actual scratches) all over, I even found one little rust spot at the indent on the lower half of the driver door.
What the hell is going on? I remeber Dodge used to have horrible paint back in the 80/90s? with caravans, has the symptom returned?
I compared my sides to my moms car and her car is nearly flawless for being a 2000 neon with 50,000 km on it, with several road trips. My truck hasn't even had to survive a full winter yet (Gravel, salt)
What can I do? Tommorrow I'm going to clean it up again so there are no water stains and take it to my dealer who sold it to me off the lot. see what she says...then I start climbing the ladder...if I don't get what I want Then it's off to Toyota to get rid of the dak.
My superviser has a 04 and spends way more time driving it to the millsite and his paint isn't even nearly noticeable compared to mine
