1 - 7 of 7 Posts
Bitches come and get some
Components in case you are interested (I just copied all this from my invoice):
Transmission Section
*"Transmission Rebuild 100% New Transmission
APS Ultra Premium High Performance Master Rebuild featuring Red Eagle Frictions, Kolene Steels, Torrington Roller Bearing kit, Premium seal & Gasket kit, bushing kit complete, New premium rear band, Both Brand New One-Way Heavy Duty roller sprags, Thrust washer kit. Perfect for Street/Strip Action!"
*Early Model Year Sensor Premium
*APS Reprogrammed Valve Body with TransGo Complete Shift Kit and APS Custom Tweaks
*APS Throttle Valve Kit (Increases Shift Points)
*APS Precision Custom UHD Sintered Cast Band
*New Version APS Aluminum Accumulator & Blocker Rod
*APS High-Ratio Band Actuation Arm
*High Capacity Direct Drum 4 Clutch (Increases Torque Capacity by at least 33%)
*High Capacity Direct Drum Release Springs (Fixes 2-3 Shift Timing Problems)
*APS No Flip Rear Servo with Cushion Blocker (Fixes 1-2 pulldown on manual shift!)
*Update Pressure Regulator Valve (No Buzz)
*Correct Filter
*Correct Neutral Safety Switch
*APS Custom Switch Valve
*No Leak Reusable Pan Gasket
*Blueprinting All Clearances (Inc All Parts)
*No Bend Band Apply Strut
*Specific Rate Intermediate Spring
*Brute Force OD Spring
Converter Section
*Custom Heavy Duty High Stall Converter (2500/2600 Bracket Fighter)
*One Piece Custom Piston Upgrade
Wayne has been awesome to deal with, very helpful. I've heard great things about these transmissions. Hopefully I'll be able to actually give feedback about it sooner than later.
Discussion Starter · #7 ·
Actually, it was $3927 without the core...$3727 with the core. I never ended up sending my core back to them, so I didn't get the $190 back.
1 - 7 of 7 Posts
