1 - 6 of 6 Posts
I plan on putting these on a 98 Durango and wanted to know if I will have to re-wire anything or is it a simple pull the old ones out and put the new ones in. Let me know.
thanks
New Lights
You can use the stock wiring. Depending on your local laws, you may need to replace the smaller outer blub with an Amber one (along with the turn signal lights). Usually the trun signals I have purcahsed have come with this and all that is needed then also, is to cut and butt connect the stocking wiring with the new wiring. Hope this helps, its not as bad as it seems. Later.
1 - 6 of 6 Posts
