1 - 6 of 6 Posts
Scrapin the Coast
My check engine came on in my 2000 Dakota so I got the code and this came up. P 0720 anyone have an idea of what it is?
Home Owner....
that is your Trans Output Shaft Speed sensor....something you can replace yourself.
is your truck shifting weird.... like it dont want to shift outta first??
yep
0720-Low Output SPD Sensor RPM, Above 15 mph- The relationship between the Output Shaft Speed Sensor and vehicle speed is not within acceptable limits.
Output shaft speed is less than 60 rpm with vehicle speed above 15 mph (4-speed auto. Trans. Only).
Scrapin the Coast
Discussion Starter #4
Believe it or not I did notice that it was shifting weird. When I would take off it would shift past 3000 rpm. Another question I have is after I fix the problem, how do I get the check engine light off?
Home Owner....
will shut itself off. if not, unplug the connector on the ECM closest to the fire wall and reconnect it.
1 - 6 of 6 Posts
