1 - 7 of 7 Posts
Folks ,
Not the bulb, the whole thing ... I have to remove the bug guard in the front and the only place where it is screwed in is underneath the headlamp assembly ? any ideas ? :help:
most eyelids are just clipped, hmmmm. but to remove the headlight you have to remove the signal light(1 screw- star tip between the headlight and signal light) then the headlight is held on by 3 bolts. i forget what size they are.
Pearls Before Swine
Pretty sure the screw that holds the corner light in is a 15T
and I THINK the headlight bolts are somewhere around a 13MM or 14MM socket. I just had mine all pulled apart the other day so I think thats correct.
The screw inbetween the headlight and clear corner lens is a T10, which allows you to remove the clear corner lenses. Once the corners are out of the way, you will see the 3x 13mm headlight lens assembly bolts.
1 - 7 of 7 Posts
