1 - 5 of 5 Posts
I've been looking everywhere for kits but the most I have found was a 3" torsion key lift. If someone could help me out...hoping for 4"+ suspension kits
The problem with the '02 Dakotas is that none of the lifts available for the 97-99 will no longer work. In 2000, Dodge changed the steering system to a rack and pinion steering system. While you can physically bolt on the suspension components, the kit does not accommodate the rack and pinion. The one possible option is to retrofit an older steering system…..but this will not be a simple bolt on swap because apparently there was also a slight change to the frame design, for the rack and pinion system to be used.
Ed
1 - 5 of 5 Posts
