Looked it up, couldnt remember which was which, if your a math wiz, this should help!
How do you run speakers in parallel?
Wiring speakers in parallel is simple. Connect the + terminal on the amp to the + terminal on each speaker. Then do the same for the - terminals. An example of this is shown on the right. For two 4 ohm speakers, the total impedance would be 2 ohms. To find the total impedance of speakers in parallel, use the formula below.
Total Impedance = 1/[(1/speaker1) + (1/speaker2) + (1/speaker3)]
Total impedance is lower.
How do you run speakers in series?
It is not suggested that you run speakers in series. No two speakers will be exactly identical, even if they are the same model from the same manufacturer. This means that they will act slightly different from each other when presented with the same input signal. When wired in series, these differences will cause distortion in the form of back EMF. Wiring two 4 ohm speakers in series will result in the amplifier seeing an 8 ohm load.
Total Impedance = Speaker1 + Speaker2 + Speaker3
Total Impedance is higher.
http://www.lalena.com/audio/faq/wiring/
