I'm adding an aftermarket 7-pin trailer wiring connector (for lights+brakes) to a 2006 Dodge Dakota. The instructions for the kit I bought result in there being an "always hot" 12V pin in the connector (with a 40 amp breaker). This seems like a safety hazard (e.g. little kid opens and touches the connector and shorts the battery across their finger) and could also cause the trailer to drain the truck battery if it's plugged in for a long time (e.g. at a rest stop).
Ideally, I'd like to add a relay so that the power supply is only "hot" when the vehicle is on.
I'm still researching this, but does anyone have any ideas on how to accomplish this easily?
I'm hoping there is some sort of standard relay for this type of application that can plug into some available slot in e.g. the fuse box or something. I could splice into some other "hot only when running" wire, but I'm considering that a last resort.
Thanks for any suggestions!
