C
code3
·Guest
My ABS is locking up when brake applied hard. This shouldnt happen and should pulse. Dont know, any ideas?
That's not how ABS works. You have it backwards. When you apply the brakes in an ABS equipped system, the ABS senses wheel or axle stopping and releases brake pressure to prevent wheel lock up.BlackDak said:If you have an ABS sensor that is going bad or is not reading correctly, the ABS computer could read that as wheel slippage and activate the ABS.
