2000 Durango w/ 5.9L
ABS engage at 5mph constantly, without heavy application of break, and sometimes remain on after foot its taken off brake. Any ideas (no engine light or computer code)?
From my experiance -Being a Ford Tech- I'd say you have an abs sensor on its way out. Basically it's telling the computer as you slow down that one wheel is running faster then the other and turning the abs on. This wont set a code as the computer thinks the wheel is just slipping. Unfortunatlly the only way to tell which sensor it is -unless it has some damage to the exciter ring- Is to use a scan tool test drive and monitor the wheel speed sensors to see which one is out of sync.
