Ok so I'm new to this truck (97) and this forum. So my brake light and abs light is stuck on. What I've read is to replace rear wheel speed sensor so I just did that and the lights still on. I check fuse box it's listed but no fuse in it and no post to it. I also read of theses no abs up front then the won't be a fuse for it. So what's else should I check or replace
Sent from my SM-J100VPP using Tapatalk
I’ve got same issue with a ‘99 and read the same repair. Do you still have issue with warning lights on?
I replaced the speed sensor and both lights are still on. Also my e brake doesn't work But I jacked the rear up and one of my back brakes doesn't work so I'm guessing that has something to do with it
I know on other vehicles that is a sign there is a problem with the ABS module when you have the parking brake light and ABS light on at the same time. Cracked solder joints on the ABS module PCB.
