1 - 14 of 14 Posts
iv tryed searching the forum but cant find anything like my issue...
my truck starts fine and drives fine but after no certain time the truck will just start runnning like crap and turn off and wont start again intill you let it sit for an hour or so... then it will start right up and run fine?????? im lost.... could it be the fuel cut off relay switch? any ideas would be great....
where is the fuel cut off switch located on are trucks?
· Shoo Shoo Retarded Flu !!
clogged cat perhaps. or possibly a bad ignition coil come to mind, considering your symptoms
Discussion Starter · #4 ·
OK guys i replaced the ignition coil but no luck it started doing some new things... today when i was driving on the freeway and the truck just turned off the check engine came on.. i was just letting the truck coast for a little bit then out of no where the truck started by its self. i was like WTF!!!!! im losing my mind.
what would you guy replace next?
Classic sign of a fuel pump but a Crank sensor is a close second
When it dies get keep some CARB or Throttle body Cleaner not brake spray or Ether. Some brake cleaners will ruin cats and O2 sensors don't take a chance. Ether is good for flooded or cold cars not what you need it for
Spray some carb cleaner in the throttle body and see if it starts, if it does the crank sensor is good if not check fuel pump time
A quick fix is to get under the truck and give it a cpl wraps with your fist and see if the pump starts for a while.
I am leaning towards the fuel pump because you say the car starts running like crap first not just dies and wont restart
:drive:
:drive:
You've never had an eratic crank sensor? Will do the same thing. Im not saying it couldnt be the fuel pump though.
1 - 14 of 14 Posts
