Just bought a 99 Dakota rat. It was at a local shop not running, but the mechanic said that it needed a new fuse box under the hood. I’m trying to do a little research to see if the fuse box is specific to the rt model or are they interchangeable with others? Any info is greatly appreciated! Thanks
The fuse box, Power Distribution Center, would be the same for '99. It varies in other years.
The wiring harness itself may vary slightly. It "should" be the same if you are swapping one from either the 5.2 or 5.9.
