My 99 dakota with a 5.2 stays running normally after turning the key off and removing it. It's definetly an electrical issue. I've replaced the ignition switch did not fix it. Today I pulled the fuel pump relay and it still continued to run just idled up and down. I ended up pulling the ignition coil boot and would rather not have to do that again lol. Anyone have any other ideas I may be over looking?
Also incase they may be linked and likely are. Other electrical issues with my truck are, gas gauge does not work I've replaced fuel pump assembly with fuel level sender. There's a short in my console/purge slot interior fuse box. Will blow any fuse but a 30a should be a 10a, which is turn causes doors to repeatedly lock while driving, it also would also mess with the anti theft system untill I took an ecu and ctm from my totaled 5.9 that did not have anti theft and put them both in the 5.2 as to not have to worry about the system stopping my truck from running.
