I did some research and apparently, this is common. My brake lights don't work. I have regular lights when i turn on my headlights and high beams, but when i press the brake, nothing. I replaced the #7 fuse and still nothing, except now, the brake light on the dash came on. From what I research I am being told its the Brake Light Switch? Again its a 95. V8 5.2L Engine. Any suggestions?
Got out of Dodge.
If the quick, easy fuse replacement didn't help, I would think the brake light switch would be the next culprit. The brake light on the dash board could be a totally different issue. As your brake pads wear out, the brake fluid goes into the brake lines and lowers the level of brake fluid in the reservoir. This causes the dash lights to come on to indicate a warning/problem.
