Yes you can use the 5.9 however use your manifolds from your 92 as they have a larger inside diameter than the newer ones. you also will need to put the obd1 on the 5.9 or put the obd2 controls on your truck.
I think (and could be wrong) the obd1 on the 5.9 would be easier... basically turning the 5.9 into a long block replacement for the 5.2.
also while you have it apart do the kegger intake mod then get one of Dwights modified TB's
