Hey I am new here and I am in need of help to better understand my truck. I have no headlights, tail lights, spedometer, or horn. While trying to trouble shoot and test wires, I no longer am able to get it to turn over. I have restored the interior 85%. Had to remove the bed to get to a seam behind the cab that was the cause of a leak (hence the interior restoration). Didn't want to put the bed back on until I figured out the problem. Things I have done so far are replace the:
Distributor cap and rotor
Spark plugs and wires
Fuel pump
Fuel filter
Crank case breather
PCV valve
Power steering lines (both the pressure and return)
Flushed the coolant system
Air filter
With all of this, I cannot see the reason why this would be a lost cause. Does the bed not being connected to the ground have anything to do with this? Am I missing something? Am I to just replace the entire wiring harness? Please let me know what your thoughts could be.
Fuel pump
Fuel filter
Crank case breather
PCV valve
Air filter
